1 - 13 of 13 Posts
Our plumbers have not returned our calls to move some lines in our house so that we can finish our basement. They did the original installation and put in the Pex line that expands over the fittings. Soo.. we decided to move these on our own. Bought the tool, all fittings and line, watched an online video to see how the tool worked. When we were done, we turned on the water and at almost every connection there is a slow drip. I did not expect this at all after the research I have done on this. Is there something I am missing? Should we wait a certain amount of time for the line to shrink down? Does heat need to be applied? Unfortunately, there is only one plumber in our area that works with this. There are no supply stores in the area so I feel as though I am at a loss here. Any help would be extremely appreciated. Very frustrated right now.
Premium Member
Did you buy the proper fittings for the system your using? Did you put the expansion rings on too?
You bought the Pro Pex Expander tool? The one that is $400 by Milwaukee?? Can you post a picture? We may be confusing terminology. There are a few ways to make PEX connections, crimp, compression, etc. Big box stores sell the crimp tool, but I dont think they sell the expander tool.
Master Plumber
Is he the only plumber in town, Videos make things much easier than it looks at least you had leaks now and not a ripped joint a month later, when your out of town maybe? oh and when the insurance company asked who did the work. AH i did, sorry sir claim denied failed to use qualified professionals to make alterations to your home. seen it more than once, call a plumber that's not like changing your kitchen sink faucet. sorry for being blunt.
Civil Engineer
That looks exactly like the Wirsbo expansion tool I use for all my work. I have never had a leak, so I am guessing you are not using proper technique. Here are a few possible reasons your installation is not working:
1. It is necessary to fully expand the PEX prior to installing it on the fitting. For 1/2 inch pipe, this generally takes 4 expansions of the tool, and I always rotate the tool approximately 1/4 turn between expansions. For 3/4 inch pipe, it seems to take about 8 expansions. I have not worked with 1 inch pipe.
2. It is necessary to install the ring over the end of the PEX pipe. Once in a while the ring will slip from the end during the expansion, in that case it is possible to get a drip, so if the ring slips, my suggestion is to start over.
3. It is necessary to use new fittings in most cases. It is easy to get a drip if you remove the PEX from an existing fitting by cutting the PEX off with a knife, as you can score the fitting. In this case, installation of new PEX will invariably drip. If you need to remove PEX from an existing fitting and you plan to reuse the fitting, you should cut off the PEX ring, then heat the PEX pipe with a torch until the PEX turns translucent. Once the PEX is translucent, you can pull it off the old fitting without damaging the fitting.
4. There are many different companies that make fittings which are supposed to work with Wirsbo rings, however I always use Wirsbo fittings as I am skeptical about the quality of fittings from lower cost competition. You did not mention what brand of tubing, fittings, and rings you are using, there may be a compatibility problems.
5. Wirsbo states in their manual that you are supposed to wait about 20 minutes after installation before turning the pressure back on. I try to follow this rule, however I have pushed it to as little as 10 minutes on a few occasions without issue.
Your comment is a bit silly, especially on a DIY site. While registered plumbers are wonderful and have many good uses - particularly in the design of plumbing systems - running pex-a with expansion joints is much easier than changing your kitchen sink faucet, and drips can happen regardless of whether it is copper or pex, or DIY or plumber. I'm reading this thread because I've run a lot of pex-a without drips until I tried it last night with a brand-new expansion valve manufactured by SharkBite (not, not a sharkbite fitting), which I've used successfully many times before. Something was apparently different. This great site gave me several things to think about.
A "Handy Husband"
And you waited 8 years to make your very helpful comment!
Sent from my Lenovo TB-X606F using Tapatalk
1 - 13 of 13 Posts
