Hi. This is my first post. I am planning to tackle finishing the basement in our house; in the middle of clean-up, and noticed this. The house was built in the 60s, and I suspected that this is a result of water pressing up against the wall from roof water run-off. The eavestrough on the front of the house is pulling away and lets water dump near the foundation (roofer is already signed-up, but we need to wait for warmer weather). There is a sump pump near this area that does work, but never runs (ie not enough water to activate float switch). There is no water ever present on the basement floor.
I have had a wet-basement guy in who has suggested installing a product where they remove 10" or so from the concrete floor, install "foundation guard" which channels water to a sump pump, and then repour the floor over top. This is quoted at $4300, and is to solve for water pressing up from beneath that is believed to be wicking up the wall. I cannot tell if this is a continuing process, or if it will be cured by the new eavestrough and making sure the water is dumping the well away from the foundation. Also I am considering either 1" closed cell foam adhered to the basement walls, or spray foam, and wondering whether either of those will form a sufficient moisture barrier that I do not need to pay the $4300 for the foundation guard. Sorry for the long post, but I have no experience/knowledge on this kind of topic, and looking for opinions.
Thanks!
Jeff
Thanks!
Jeff
