is it good to used corrugated rebar for equipment grounding?
R rolan · Registered Joined Jun 18, 2011 · 1 Posts Discussion Starter · #1 · Jun 18, 2011 Only show this user is it good to used corrugated rebar for equipment grounding?
R Ron6519 · Registered Joined Mar 28, 2007 · 11,194 Posts #2 · Jun 18, 2011 Only show this user rolan said: is it good to used corrugated rebar for equipment grounding? Click to expand... No, it will rust and the rust will insulate the connector from the wire and you will lose your ground. Ground rods are copper for a reason.
