Hi everybody, first time posting here, just found this site and it certainly seems like a treasure trove of information.
I have a question about an epoxy roof sealant product I have been eyeing, for use on a home I made an offer on. The house has asphalt singles that seem to be in deteriorated shape, and may be leaking in some parts- judging from some stains in the inside of the home.
The home needs quite a bit of work all around, so started looking at options for the roof, in order to avoid doing a complete shingle replacement right off the bat. So doing a search online I found this product (I won't provide the name here, not interested in doing any promotion for it) that is a water based epoxy that you apply by brush, roller, or spray right over the shingles, over the whole roof, preferably two coatings if they are in bad shape. The company states that this will completely seal and waterproof the roof, and that it will last for some 15 years.
So I asked my realtor about it (and will talk also to my inspector, when and if our offer goes through) who told me that products like these have been around for a while, but that the problem is that the seal can trap moisture between the new coating and the old shingles and roof, thereby causing wood rot and even more deterioration. Makes sense, but is that truly the case, for producs like these? Or if so, can this be avoided somehow? The cost, as best I can figure out, for applying this sealant would be around $1.5k, which is better than the $10k minimum I would have to spring right after buying the home. My intention is to replace the roof maybe 2-3 years down the road, after I fix all the other things that need immediate attention elsewhere (and can recover a bit financially after the purchase).
So, has anyone ever used epoxy roof sealants for this application, applied drectly over shingles? Any experiences with this or thoughts on viability, in particular the issue of trapping moisture?
Thanks in advance!
Paul
p.s. I did do a search in previous posts but did not find a specific answer to the questions.
p.p.s. I attached a few pics from the site, showing the product applied:
