Well, this very well could turn into an insurance claim. Trying to get a little background information before I go reaching out the insurance adjuster, as this building is "non-conforming" and I'm not sure the city will let me rebuild it due to current zoning/setbacks. It was built 50-70 years ago and lots has changed since then (duh).
Pretty clearly someone hit the building right at the corner. Appears to have pushed "in" (to the left) the wall at the 4th course of cinder blocks. I assume the width of the gap is approximately indicative of the amount the top 3/4 of the wall was pushed in.
So the questions:
A.) I'm sure this is bad, but "how bad" -- i.e. is it in imminent danger of collapse?
B.) I've done very little/no work with cinder block walls. Is there any hope of repairing this corner without totally demo'ing it and starting over? FWWI, the blocks are hollow (i.e. no fill), old, and they seem really soft (I recently drilled a 1" hole in it and it took about 3 seconds to get through with a hammer drill and a good bit)
C.) Assuming the corner cannot be 'repaired', is there a method to rebuild just the corner/two walls, or is the entire building destined for a date with a dumpster?
Left side appears ok. The entire building had 'issues' (albeit relatively minor) before this collision event. Broken bonds, day-light coming through the cracks etc. Unfortunately the security camera was not installed before the collision (it was the motivation for it)
I put the broken pieces here for no good reason. Figured it might be good to save them (??). You can see the black 'rub marks' (guessing black enamel/powder-coating from a large truck?)
Left side of the structure seems basically unaffected
Amazingly, the garage door still rolls up, though definitely is not as well in alignment as it used to be (that is actually how I first noticed the issue -- it was stiff to roll up). The bond-break two courses down from the top is pretty easy to see in this picture (and of course the gaping ones own below)
This is an interesting picture. I think that the blocks on the right (actual corner blocks) stayed put, while the left 'middle' block was pushed to the left as it was attached to the block that was actually hit.
Pre-collision picture showing the structure as a whole.
So the questions:
