Make the hole indenticle to the size of the conduit or conduit body (LB).I just need to know if I should just stick the conduit through the wall and call it good, or if there's some sort of beauty plate I can put in to make it look cleaner.
Got a code on that?MC/AC is not rated for outside the wall without protection. You need to run NM inside the wall to a junction box that is accessible and then if it goes outside the building, attach EMT with the proper fitting to the back of the box.
EMT is not listed against physical damage any more than flex. The flex can be used as a sleeve that same as EMT.To add, you can only run THHN/THWN through that flex. You cannot run NM through it. If needing to protect NM, you can use a section of EMT to run it through to keep it from getting damaged (ie Unfinished Basement where you have to drop a run of NM for a Branch circuit to an outlet. You can use the EMT on the wall to pull the NM through to the box for the outlet, so that nothing can cut into the jacket and conductor insulation).
False againMC/AC is not rated for outside the wall without protection. You need to run NM inside the wall to a junction box that is accessible and then if it goes outside the building, attach EMT with the proper fitting to the back of the box.
Happens a lot with certain posters. When you try and correct them they just put you on ignore so they never learn.False again
