Hi tried this post under the HVAC heading but wonder if it shouldn't go here cause I need advice on engineered joists and not necessarly HVAC.
Hi, builder didn't follow my request to keep ceiling height in the garage at 10 feet by allowing the HVAC contractor to install the flex duct below the ceiling and then the builder box'ed it in and covered with sheetrock right down the center of the entire garage. Well I'm now at about 8 feet and can just barely fit my Kobota with its rollover cage into the garage. Had planned on having a place for shelving etc., etc. The garage is really not what I wanted and I'm looking for ways to fix it without costing me my left lung. The HVAC contractor offered to run sheet metal ducts that would be only 5 inches deep and 20 something wide. I have an apartment on the second floor where we live so some kind of duct work in necessary. I have a heat pump to handle our heat and air conditioning needs. The price to change out what I have with what the HVAC contractor offered is just too much to spend right now and I was just thinking about it today and... Well that is why I'm here. I have an open span across the garage thanks to the engineered lumber that spans the 24 food deep garage. The engineered joists are about 16 inches tall and I was wondering how much I can cut out of the center plywood sections and possibly run duct through them. Yeah I know they should have used trusses and I could have run the ducts easily thru them. Well I asked for that and got this. So here I am. And any all suggestion would be appreciated.
thanks
Walt
thanks
Walt
