Hi,
I'm thinking of installing engineered hardwood on a floor in my house. Essentially, what I have is an approx 10ft long hallway. At each end of the hallway is a bedroom. See the attached layout for more detail.
Basically, I'd like to put a transition under each bedroom door. The planks run perpendicular to the transition (I guess that's obvious).
What I'm worried about is the planks that run in the hallway between the transitions, since they won't have any room at the ends (I'd like them to butt up tightly with the transition pieces).
I don't like the look of the "regular" transition pieces that sit on top of the wood and would prefer one that sits inlaid or flush.
So:
1) Is there a name for this type of transition?
2) Can I do this with engineered hardwood?
3) Are there any tricks to help me make the planks land tightly against the transition (i.e., do I cut each one carefully, or lay them all and mark with a straight edge? Cut in place?)
4) Am I "way" better off making it one continuous floor?
Any and all help is appreciated!
I'm moderately competent at this sort of thing, so if precise cutting is required I'm sure I'll be able to do it (but I will make a lot of scrap...) but I don't know if the floor be ok (or will it buckle?).
Thanks,
Steve
So:
Thanks,
Steve
