Good Day,
I'm installing Lauzon Engineered Hardwood Flooring this weekend and thought I'd though a question out there last minute.
What size staple should I use? I'll narrow the opinions down (some info may be irrelevant but here incase it's needed)
Thanks!
Josh
- I'm going to rent a Bostitch MIII stapler today and the local store only has 1-1/2" 15GA and 2" 15GA staples available.
- 1000 ft2 of board
- Lauzon requires the installation to be staples (not cleats or nails) but says 1-1/2" and 2" would work.
- My subfloor is 5/8 T&G spruce (43 years old) with joists 16" on center (second floor - heated basement below)
- Underlayment (http://www.fortifiber.com/aquabar_b.html) will be used and is approved by Lauzon
- 90+% of installation will have boards running perpendicular to joists
- The hardwood is 3/4" thick, two ply, top ply maple, bottom ply SPF with grain perpendicular to maple top
- http://lauzonflooring.com/wp-conten...allation-Warranty-Guide-Engineered-Expert.pdf
Thanks!
Josh
