I have a 1920's home that has an enclosed back porch 8x20. It is cold in the winter and hot in the summer. It costs me a fortune in heating and cooling since it affects the whole house. I took up the floor and found a dirt floor crawl space. I insulated the concrete foundation walls and put a vapor barrier on the dirt floor. (I did not put insulation under the vapor barrier) There is fiberglass insulation already under the floor boards (between the joists).
Question is: should I add more insulation to the dirt floor or is the vapor barrier and the fiberglass enough? The existing floor is old T&G, should I put roofing paper over the T&G before laying the 23/32 OSB or should I use the plastic vapor barrier?
thanks in advance.
Dan
thanks in advance.
Dan
