1 - 6 of 6 Posts
the emt worked fine ,but I will use armored for the ceiling light runs . It cost the same as THHN but you do not have to pull the wires or make the 10' connections
Use MC cable not armored cable. Or do you mean MC cable? I would run EMT up to the fixture and set a box. Then run a short (whip) section of MC from the box to the fixture. This is how the pros do it.
If this is exposed, you should want it to look as good as possible. :thumbsup:
1 - 6 of 6 Posts
