I am in the middle of upgrading some 1930s BX in my house. Actually the whole house is being re-wired. I am working with a licensed electrician, who has pulled the permit. He installed a new service drop, meter base, and 200 amp panel. I am running the cable and making up the boxes; he will make sure I do it correctly.
I've done a lot of reading about wiring techniques through various DIY books. Further, I have studied electricity and magnetism in college, so I have a theoretical background beyond most DIYs. I am the first to admit that this in no way means I have an in depth knowledge of the NEC, but I am learning.
My question is with regard to protecting Romex in EMT. In my stucco covered brick foundation basement, there are a couple of places where I need to run down the walls, where unprotected Romex is unacceptable. My electrician told me to protect it in EMT.
I've done some reading online and sense that most electricians, if they are running Romex in EMT for a short distance, seem to leave the sheathing on the cable. I have read assertions that the wires used in the stripped Romex are unlabeled THHN/THWN, but are unlisted with UL (or other appropriate listing agency). Because of the lack of labeling, most say stripped Romex conductors may not be run in EMT once stripped of their sheathing.
I took a look at the only Romex-in-EMT work in my house, which was performed by my electrician, and which supplies my heating system. This was for my reference, so I could do the work to the same standard. Regarding the run: it is a short run from a joist down to a thermal protection switch. It has the NM-EMT transition fitting at the end of the 1/2" EMT. The EMT makes a 90 deg. bend, drops down, and connects to a 4" utility box. What surprised me is that he stripped the sheathing off the Romex for the portion within the EMT.
Now, I can certainly see that Romex stripped of its sheathing would do a much better job of shedding heat than that in the sheathing. What he has done seems sensible, outside of the question of listing.
I am trying to decide if I should replicate what my electrician has done. It is his name on the permit and I feel I should follow his practice. On the other hand, if unlabeled conductors are a code violation, then I have a problem on my hands.
I guess I'm looking for some thoughts on this matter. I'm probably going to have to bring it up with him, but I don't want to come across as questioning his skills. Again, he's a licensed pro (a fact I have verified), has been in the field many years, and seems knowledgable. And as a bonus, he's willing to work with me, so I can do some of the grunt work to save some dollars. I didn't find many guys like that when I was looking for an EC. So I don't want to get on his bad side.
Any thoughts?
Any thoughts?
