Hi All,
In short, is this doable / safe/ etc.? I would like to cut out a 4 inch strip of drywall in my garage ceiling in order to mount the garage door opener belt high enough - It needs to be 1-2 inches higher to avoid contact with the garage door as it opens.
Could you please advise if this is doable? Any foreseen issues? Fire hazards, code violation, etc?
More Details:
I am installing a garage door opener, the Chamberlain B750, and hit a snag - low clearance. The top of the door comes within an inch of the ceiling at its highest point (about a foot into opening), and so the belt pulling the door doesn't quite fit, even when mounted adjacent to the ceiling. Once the garage door flattens out in its ascent there is more room (3-4 inches), so it is really just that one point where the door would hit the belt.
I would like to mount the belt at a slight incline as it approaches the garage door from the opener motor (ceiling level), so that it passes into a cutout from the drywall, to a mount that is just slightly above ceiling level. It's a matter of inches.
Barring mysteries that lurk above the ceiling (let's assume it is clear of wiring, studs, etc.)... is this theoretically safe and practical?
