I have an existing Electric water heater that needs replaced. i have the new water heater int he garage where it has remained in the box for the past 2 years
. I have dreaded installin git due to the intimidation of soldering the copper pipes where adjustments are needed. although the water heater is not "broke" i would like to attempt to swap the water heaters out here in the next few weeks or so.
ANYWAYS, the existing water heater is inside our house and is in one of our closets. so no where near outside temps. the water heater was installed on top of bricks which leaves it about 2-1/2" off of the floor.
why was the water heater installed on these bricks? since the water heater is inside, is this required for the new water heater as well? can the new water heater just be placed on the floor with no offset? what is the reason for bricks?
now i did read that bricks or some type of foot is required for GAS water heaters for air flow on the bottom. is this the case for electric?
