1 - 10 of 10 Posts
I'm new here. I apologize in advance if a similar question was answered somewhere already.
Question: Would adding a ground clip, as shown in the attached photo, satisfy code and increase safety? (The wiring diagram is for a similar timer with a ground wire.)
Details: I bought an electronic countdown timer from ebay. (GE5100E30-71D) It has a line, load, and neutral wire. It does NOT have a ground wire. The timer will be mounted in a non-metallic box and control a bathroom ventilation fan.
My understanding is that all switches should be grounded. I've been adding pigtails and grounding the switches as I replace them. We're changing the colour anyway.
If the UL listed device does NOT have a grounding terminal?
No ground terminal. See photo of back.
Maybe this timer is an older model? When did the code change to require switch grounding? My 20 y/o house has ground wires in the boxes, but none were connected to the switches. Well...the old switches didn't have ground screws either.
I bought a similar timer for another room and it did have a ground wire. I've seen other timers with two black wires and a ground wire. The dimmers I installed also had ground wires.
The timer is designed and tested to be used with out ground.
But some codes require that a ground be available at the j box.
So what is your concern ?
It would be safe to use with out a ground,
or it would not have been listed.
But if one is avaiable thats fine too !
NO PROBS !
Discussion Starter · #6 ·
NO PROBS !
First concern is always safety. Second is code compliance, which helps with the first concern. I'm giving it extra consideration because the device is in a bathroom, but at this point it seems as good as it could be.
I would imagine that if an earth is available at the box,
And you use a switch that is double insulated,
and rated as such.
Then there should be no problems code wise.
If the plate is metal and the box is earthed
the screws are metal
then the plate would also be earthed.
So is safe !
Discussion Starter · #8 ·
and rated as such.
So is safe !
OK. I found a motion detecting switch in a retail store that was wired the same way; without ground. They must be OK and code compliant.
The box isn't metal, it's...something dark brown. Adding the ground clip is only a minor inconvenience, but maybe it's also over-kill.
By the way, if a lamp post is buried in the actual ground, is there any need to attach a system ground wire to it?
If the switch is double insulated and rated as such,
then an earth might not be needed.
But if it gives you more peace of mind then go for it !
Most electricains would say a proper earth wire is
a safer way to do it.
Discussion Starter · #10 ·
Right. Plus, it's possible to create a "ground loop" condition, I guess. So, yeah, I used a ground clip on the lamp post, too, just to be thorough. heh
The one place I haven't used the ground clips are on the metal boxes in the finished part of the basement for which they were intended.
1 - 10 of 10 Posts
