1 - 20 of 20 Posts
Super Moderator
I have a garage with no electricity. How do I run electricity from the houe to the garage? How difficult is it to do? :(
With such few details, it will be impossible to tell you.
How far? What do you want to do out there? anything in the way?
DIY'r
There are quite a few threads on this forum on that very subject. I assume your garage is detached?
These might help to give you some ideas:
http://www.diychatroom.com/f18/wiring-new-detached-garage-studio-24000/
http://www.diychatroom.com/f18/detached-garage-sub-panel-3627/
http://www.google.com/search?rlz=1C...site:diychatroom.com+power+to+detached+garage
Like jbfan said, you can also provide some more info on your structure and your requirements to get started.
To answer your question generally, it's fairly difficult on a scale from replacing a switch to rewiring a house.
Discussion Starter · #6 ·
with such few details, it will be impossible to tell you.
How far? What do you want to do out there? Anything in the way?
from panel box to garage, 40ft. I want to install an automatic door opener and some lighting and out lets for small hand tools and appliances (radio,batterie charger). Nothing above ground and nothing below that i'm aware of.
Banned
I have 10/2 UF running to my garage for the opener, 4 outlets, and 3 lights. Used to be controlled by a switch in the house, but when we rewired, did away with the switch in the house, and have direct from the breaker panel to the garage, with a switch for the lights in the garage only.
Since we did not need to have 220 out in the garage, only ran with a 20amp in the main, and used a 2 breaker sub-panel in the garage to have a 20amp for the outlets, and 15 amp for the lights. Makes things a lot easier. Plus added a GFCI for the outlets in the garage, and a leg with a GFCI for the outdoor outlet.
what are the benifits
Capability and expandability. It gives you the option of adding more stuff later. It's the best way to go. Second best is a MWBC (multiwire branch circuit) and a single circuit is last on my list. Use the search function. You have no idea of how much information is already typed (pictures and diagrams too) ready for you to use. Then after you get the basic idea, THEN ask for more info if you need it. You probably will not need any more help. :thumbsup:
Banned
If you only want a few watts, max, or a few watt-hours each day, go solar.
That will work with getting lights into the garage at night :no:
Solar is expensive, a 300w panel & battery install would be a lot of $$
For greatest flexiblity I'd install a small 100a panel & feed it with 60a
But that depends upon what you have for house current & exisitng loads
There are a ton of threads onhere as JV said that explain this in detail
You do know that you are not in code by running Romex through Conduit all the way.
The NEC doesn't apply to me, as I'm out of jurisdiction. However, the ground temperature is about 20F for 6 months of the year.
Can you imagine, cutting the Romex installing a box, running separate conductors in the conduit, another splice in a box at the other end!
That's just another rule that was dreamed up to cover somebodies back side.
1 - 20 of 20 Posts
