Is the outlet always HOT or do you want the outlet controlled by the switches.How do I change a 3 way switch wiring and install a 3 way switch with an outlet included.
Nice drawing!Is the outlet always HOT or do you want the outlet controlled by the switches.
In the diagram below, the outlet is always hot. As long as you have a neutral at the switch location you can add the outlet. As long as the current 3-way switch setup is functioning properly, just replace the wires from old switch to the new switch.
No ground wires show for ease of drawing.
I use microsoft paint program, Turn the canvas light gray and get to drawing using the line tool. For the devices I just save piictures and paste them in.Nice drawing!
Do you do those yourself? If so, what do you use?
good tips...did not know that about the shift keyMore about Paint...
If you hold down the Shift key while you drag with the Line Tool, the line will be constrained to be horizontal, vertical, or at 45 degrees.
If you hold down the Shift key while you drag either of the Rectangle tools, the rectangle will be a square.
If you hold down the Shift key while you drag the Oval tool, the oval will be a circle.
