Hi - I need some help making electrical connections for four total lights with three switches. I'm hoping that someone can provide some guidance
- All junction boxes are located in the attic, so they will not be visible.
- I am retaining the electrical setup/layout that is currently in place. I realize there is probably an easier way to rewire everything.
- I would like the two living room lights to operate in tandem on the same switch.
- All boxes are plastic
- All wiring is 12/2 romex connected to a 20 amp breaker at the panel.
- the red lines in the diagram symbolize the white/neutral wire
Diagram is included as attachment
Thank you so much for any help you can provide
