Hello All,
I've long wanted more burners, but don't want to mess with the cabinetry around our range. So, I recently hatched a plan to put a 2 burner induction cooktop into one of the counters. The problem I have is how to power it. I prefer not to pull a new line because the panel is far away in a finished basement.
I have tried a single induction burner plugged into the wall and if too many appliances get used it pops the breaker, so the wall circuit is a no go. This isn't entirely true because the micro is run off the wall circuit, which really should be on it's own circuit, then maybe the wall circuit would be fine. I'm asking for opinions on the options I have considered or a better one. Here are the options I have thought of:
1) the range is dual fuel, so only the oven is electric (40 amp required). It is powered by a 6awg, 50amp line. I could run a conduit from the range behind the cabinets (about 12') to the induction range. This is much like a with a wall oven and counter cooktop, although this range was probably not designed with this in mind. Advantage is that I can get 240v induction range.
2) the location of the induction rang is above a closet in a room that has low electrical requirements. I could add an outlet from that circuit. Would using a circuit from another room be allowed by code?
3) I could use the kitchen wall circuit with a plug in 120v unit, and run a new line to the microwave. I would like to recess the two burners into the countertop, so does that mean it is an installed appliance and must have its own circuit?
Thanks in advance!
Thanks in advance!
