1 - 8 of 8 Posts
In my kitchen, I recently had to cut the bottoms of 2 studs of a group of four to make room so my plumber could recess the gas line so my stove would be able to pushed back to the wall. While doing this I accidentally cut an electrical line that was run BEHIND the studs. The line was run behind the studs and I'm not really sure how because it was between the stud and the outside plywood, I think?
My question is was it legal to run an electrical line this way, Shouldn't it have been run through the studs?
thanks
-Mike
UAW SKILLED TRADES
Nope ... that is to say if your description is correct. It should have been through a bored hole that would not place the cable closer than 1 1/4" to the face of the stud. This is to avoid penetration from driven nails or screws that would be standard lengths for securing typical wall coverings.
Super Moderator
If the cable was fished after the house was built it is fine to have a cable flopping around in a space.
We had recently renovated and the house was gutted to the studs...so I'm thinking the electrician, who drove us crazy by the way, should have bored a hole through the studs and not snaked it behind...
thanks for the replies, its appreciated.
Discussion Starter · #6 ·
I had to completely cut out the *bottoms* of 2 studs *out of a group of 4 together* to make room for the gas line. I cut about 3.5 inches up from bottom. I would have bored a hole however, the wall was already sealed up and this is a very tight space behind the gas stove and all the cabinets are already in. Basically 2 things were not done right from the beginning here...the gas line was not placed in the correct location by the plumber AND the electrician did not bore a hole in the middle of the studs for the line to the stove , both of which could have been easily avoided when the walls were wide open!
Electrician
I'm sorry, but I just don't believe that an electrician, especially one from New Jersey, could be wrong in any way, shape, or form. It's just not possible.
I think a picture is in order here to determine whether it was or was not legal for him to run it "behind" the studs. I'm not following what space there is between the studs and the plywood sheathing.
Super Moderator
As long as the cable is supported every 4 feet it would pass code running behind the studs.
1 - 8 of 8 Posts
