I have a small building that calculates at 66 amp total load ,with a max of 50 amps at any one time...........airconditioner and heater will never run at the same time is the reason that total will never happen,so a calculated 50 amps max,more than likely alot less than 50 ,but I used that number to be safe , with a 66 amp total combined of all draw if everything in the building was turned on high at the same time.
I calculated a water heater electric,a airconditioner window unit and a baseboard heater,plus a few plug sources that might get used to get the total of 66 amps combined.....
Here is my question,I want to use #8 wire for the main panel,so if I wire it in 220 and have 50 amps per leg that means the breaker panel has a total of 100 amps.....?
Much more than I need if it is 100 amps,but I feel better using the larger wire and having too many amps just in case.
I plan on a 30 amp breaker for the water heater and a 15 amp plug breaker and a 15 amp airconditioner breaker ,plus a 15 amp breaker for the lights and a 15 amp breaker for the heater.
EDIT: The run will be approx 100 foot or less.
Thanks for any help.
