Hello everyone! This looks like a great organization. Hopefully somewhere down the line I will be able to help others. Right now I am looking for help on my wiring. Bought house 3+ years ago. It is over 125 years old and in good shape. The electric is crazy though. I have a 200 amp service but the entire first floor and the detached garage are all on the same 30 amp breaker for all lights and outlets. Right now I am looking for info on how to put a 60 amp sub panel in the garage, which will be used as a workshop for gardening and woodwork. Want to bring wire from the main panel by attaching it to the side of house and bring into the garage overhead. Many questions.
1. Is #6 wire ok to use between panels? About a 60 foot run.
2. What size PVC pipe should I use as a conduit for the wire?
2a. Do I need to use a conduit if the right type of wire is used?
3. What type of grounding can I use? Two eight foot poles driven into the ground about six feet away from each other may be impossible because of hard clay ground AND boulders.
I am sure that I will have many other questions as project is developed. I appreciate any help and support. By the way, I will be checking, but I do not believe that there are any building inspectors in the city where I live, although I do want to do everything above electrical codes.
