I have a 20A circuit that uses too long of a run of #12 wire - probably almost 100 feet from the Circuit Breaker panel to the evaporative cooler. The cooler employs a 3/4 Horsepower motor (14.9A for fan on high and pump on). What I'd like to do to remedy this problem is to use electrical relays in order to provide power to the motor. This fix would allow me to keep my thermostat in the living room where it would be the most useful. One fact about evaporative coolers that those in non-desert part of the country may not know is that they use a line voltage thermostat, that is, the power for the unit runs through the thermostat housing. This is what made for the long wire run. So I'd like to employ the 120VAC (I measure 115V in my house) fan power wires that come from the thermostat to provide the on/off signal to the relay. I'd require two relays, for low and high fan operation. The relays would need to be placed in an outdoor rated housing. There's at least a couple of choices in types of 120VAC relays that I've seen on the internet: icecube style and rotary and probably there's many more. Of course, I'd supply an appropriately sized and wired circuit to power the evaporative cooler. I'd like to get feedback on this idea and advice on relays and outdoor housings. 8|
