This looks like the bars for neutral wires at the top of the panel. However, the ground wires are connected to individual screws that go into the back wall of the panel in a vertical row - there are not raised nor look like a bar.One of many for QO panels.
http://www.homedepot.com/p/Square-D...5-Terminal-Ground-Bar-Kit-PK15GTACP/202353315
I think so. But it's really hard to get a wire on either side. Do you have a picture of this?Do the screws have a raised lump on each side? If they do then you can put one wire on each side of a screw. They don't need to be wrapped. The lump holds them in.
Meant to say, it's really hard to get the wire on both sides of the screw. Do you have a picture of this to make sure we are talking about the same thing? And is it to code to do this in Vancouver, Canada?I think so. But it's really hard to get a wire on either side. Do you have a picture of this?
Yes, this is what I am looking for. Thank you!Here is a regular expandable box with the side removed. Note the lumps beside the screws. This is a valid code ground connection in Canada.
View attachment 240041 If
