1 - 11 of 11 Posts
i was told i might want to re-post this question here.
we are having a granite backsplash installed (along w/ the countertops), they made templates, and marked where existing outlets are on the old wall.
i am doing the electrical work.
my question. how do i raise the outlets so they are flush w/ the new backsplash? the granite is the 3cm variety, so they need to be moved out 3cm to be flush. after they finished the template, i asked the installers, and he simply said "longer switchplates screws", w/o really thinking i agreed. but that would leave the actual recepticals 3cm behind the switchplates.
any walkthroughs? or advice?
The ears of your outlets should catch on the granite just as they do on the sheetrock wall. Just get longer 6/32 screws. If the ears don't catch you'll need to use a stand-off, or a nut on the back of the screws.
Licensed Electrical Cont.
Longer screws alone are NOT a safe and legal option. You must have an extension of some sort.
Sparky Joe said:
but is it done every day of the week, yes, and is it dangerous, no.
Not by me it's not. And YES, it can be dangerous.
I agree it can be dangerous around combustible materials, such as paneling or plywood, but with the granite I would just get longer screws.
As for the standoffs I like using 1/4" pex tubing, its free from the plumbers and can be cut to any length, and is also very rigid.
Whatever you say. :rolleyes:
1 - 11 of 11 Posts
