electrical light circuit crossed with recept circuit
965 Views 7 Replies 7 Participants Last post by  dmxtothemax
I plug in a vacuum and the lights come on in ding room. Also other receptacles dont work. Where do i start.
1 - 8 of 8 Posts
Sounds like a floating neutral. Do you have lights that are excessively bright? If so, call your power company right away. This is a dangerous situation.
Loose connection from that receptacle to down stream receptacles.
Wiggle the plug with the vac plugged in and see if the light flickers.
loose connection from that receptacle to down stream receptacles.
x2 ..............
....x3
You guys are probably right. I jumped to a conclusion based on the OP's "other outlets don't work" statement.
When someone makes a post like the OP and asks "Where do I start?", my first impression is to say "Call an electrician".
We know nothing of the OP's capabilities, experience or tools/testing equipment.
shakydoctor, can you tell us a bit more about this situation and your level of expertise?
Has someone wired an recepticule into a switch loop ?
bad neutral also poss'
Loose connecttion somewhere ?
Unless it's something simple like a loose wire
then it's not really something for a novice to fix.
Recomend an electricain !
1 - 8 of 8 Posts
