I removed a range hood and called an electrician to put in a direct line for a microwave. He said I don't need one and his talking about slicing up my ceiling convinced me. So he just put in a new outlet in the cabinet above for the microwave. I bought and installed 1000 watt microwave. Plugged it in and tried vent and everything was working. Started cooking something and within 2 seconds, its power went out. And all power downstream from it. The ceiling fan/light in kitchen still worked as well as dining room light. The Living room ceiling light/fan did not work which seems to be downstream. The circuit breaker did not trip.
I called, but I am working a lot now and we could not agree on a time for him to come out. So I checked all gcfi's and flipped the circuit breaker a few times just in case. So trying to find the short, I intended to look at the wiring in the ceiling fan/light I installed two years ago in the kitchen which seems to be the next thing upstream. When I unsnapped the plastic wiring harness from the bottom light fixture to the top fan unit, the living light came on and now the microwave outlet has power.
I did not try plugging in the microwave. My question is is there some kind of GCFI within the ceiling fan/light?...I could find none. Why would it do this and should I just try and run the microwave with the the kitchen light/fan turned off?
Thanks for your time
