Having a phone has nothing to do with it - two hots, neutral, and ground are required.I have a pole barn with a 12x48 shop. I plac ed a 100 amp sub panel in the shop. I have a 200 amp main panel at my home. The distance between the two is approx 150 ft. After checking copper prices I am seriously considering using aluminum as a feed. Will 1/0 aluminum be sufficient. I understand that i will need 2 hots, a neutral, and a ground because I will also have a phone in the shop. Could you all please give me some input on this set-up. I had planned on using 1 1/4 conduit also. Thanks
