Electrical Circuit Isn't Working. Help!
A few days ago, I noticed that the ceiling fan in our morning room was off. This is left on most of the time during warmer days, so the fact that it was off seemed odd. When I checked the wall switch that controls the fan, I discovered that a few nearby switches were also not working. This includes one switch that controls four recessed lights, another that controls a remote switched outlet, a third that controls three sets of security lights, and a fourth that controls the back porch light. None of these were working.
I immediately went to the master panel and checked for a tripped breaker. Everything checked out okay. For extra measure, I turned every breaker off and back on, just in case the panel wasn't labeled properly. I even removed the master panel cover and checked the hot wire on each breaker. All breakers were working, but the power to the circuit in question was still off.
Yesterday, I discovered that all the outdoor receptacles were also off. Since I know the outdoor receptacles are connected to a GFCI outlet, I tripped the GFCI outlet and reset it. Still no power. I then tested the GFCI with a GFCI circuit tester. Again, everything was fine and according to the CFGI tester, the GFCI outlet appears to have been wired properly.
Finally, I removed the CFGI outlet from the wall and tripped it. I used a voltage tester to check the lead out voltage. Nothing. I reset the outlet and I immediately got tone, so I checked to see if the circuit had been restored. Everything was still dead. At this point, I'm at a complete loss as to 1. Why the circuit is dead, and 2. Why are recessed lights and a ceiling fan possibly wired to a CFGI circuit.
The house is only two years old and we've never had problems with any of the morning room fixtures or any of the outside receptacles. There has been no recent construction that could be a contributor either. The only thing I can recall is that I attached an air rake to one of the outdoor outlets a few days before I noticed this problem. As I recall, it was the first time I had ever used that particular outlet.
So what am I missing? Please help. This is driving me batty.
Thanks,
Kelly
Thanks,
Kelly
