I've got a permanent above ground pool that I'm running electrical for. There's already electrical at the deck next to the pool, but I need to run about 40' from the box on the deck to a box for the pump at the far side of the pool.
I've built a short (14") retaining wall from limestone boulders, with a trench drain behind it that isn't backfilled yet. The wall extends basically the entire run that I need to make.
I have on hand 12/2 UF-B cable and a bunch of 3/4" liquid tight flexible conduit. My original plan was to run the cable in the conduit for the whole run but I've learned that this stuff is way too stiff for that.
Is it acceptable to run the cable I have at the base behind the retaining wall before I backfill? It will be alongside perforated drain tubing, and actual burial depth will be about 12". I'd still use conduit where the cable enters and exits the earth.
Side question, how close to the ground can a junction box be?
Sent from my SM-N960U using Tapatalk
