1 - 20 of 21 Posts
· JOATMON
As noted above....x10 is going to be on the cheap side....about par to Harbor Freight tools....
As another referece....try out SmartHome
http://www.smarthome.com/_/index.aspx?src=WG1000015&gclid=CKP2wKWN17QCFcaiPAodO3AAHQ
One other note.....a lot of the automation switches require a neutral at your switch box, so be cogizant of the wiring needs for the modules.
And....if you do put something together....do the rest of us a favor and do a thread on it and share what you learned.....I'd much rather learn from someone elses mistakes and successes.....
Discussion Starter · #8 ·
Sure ill keep youguys up to date with the installation thanks
I've been in process of automating my house with a combination or z-wave and insteon and the biggest issue for me has been with dimmers after the cost. Not all dimmers are created equally if you plan to use them. Incandescent ones (the cheapest) generally don't work well with LEDs mainly due to them using less power than the minimum rating for the switch, unless your dimmer also has a neutral wire or you want to get creative adding resistors to simulate the load. Also if you have fancy fixtures that use a transformer box you need to be aware of the transformer type (Magnetic Low Voltage (MLV) or Electronic Low Voltage (ELV)) or you could blow the switch, the fixture, or both. I got bit by that and ended up having to spend almost $200 for a single ELV switch.
If you don't care about dimmers then it doesn't really matter because it's just an on-off relay
I've had X10 for over 30 years. I've had Insteon for over 5 years. Insteon is superior to X10. Very few problems and all have been with the software. I've lost a couple of Insteon devices early on but were replaced under the 2 year warranty without a problem. I've installed insteon in homes where the customer doesn't want to rip down an entire ceiling. and installed it in a second home with the six button scene controller. Eliminates a lot of hassle and looks a lot better than X10
· Licensed Electrician
If you are going to be working as a contractor, you should learn to do your own homework instead of relying on a DIY website.
They must have gotten better then. I put 80 Insteon devices in my house and over 6 months replaced almost all of them due to failure. Ripped it all out and installed Lutron's Homeworks Wireless.
Another recommendation would be Lutron RadioRA2. More expensive, but rock solid.
Insteon, Zigbee, and Z-Wave :thumbsup: Depending on your application.
A good number would also suggest UPB.
I agree with not including X-10. While inexpensive, I have found that it can get less reliable as you add devices. When one is talking "whole house", I doubt it would work well.
Control4 is another, but it requires a recongized contractor, I believe.
I use insteon, and have most of the house retrofit, over the last five years. It works well for me. Very few hardware issues. Communication can be interrupted by the presence of certain other electronic devices. Definitely plan to include some filters in the installation. And a controller.
1 - 20 of 21 Posts
