1 - 7 of 7 Posts
In the rewiring of 50gal water heater replacing the 10-2 copper with 10-3 copper wire. the water heater had only two connecting wires; black and red. The white wire from the original 10-2 going to the heater was attached to the grounding screw noted on the top of the heater. In replacing with the 10-3 should I again attach the wht. neutral wire to the grounding screw and run the bare ground to a cold water pipe?
Super Moderator
A two conductor cable + ground is all that is needed for a water heater. You do not need a neutral, just two hots. The white will get re-identified as a hot with black or red tape or magic marker.
I do not know how yours was functioning with a hot connected to ground.
Do not make any connections between a water line and the wiring for grounding.
Super Moderator
There is no white used on a straight 240 volt unit. The white in the cable is used as a hot conductor and is re-marked to show its new usage.
Super Moderator
Cap off the white, and connect the bare to the ground screw on the water heater.
Electrician
black to black
white to red
bare to the ground
Mark the white red with a marker or electrical tape.
Just because it is white does not mean it has to be a neutral.
1 - 7 of 7 Posts
