I noticed that we had not had any hot water throughout today and went downstairs to investigate. I ended up shutting off the supply and hot water going to and from the water heater and turning the breaker off and draining the tank (first time ever). I then took off the access plate to the top thermostat and noticed a red reset switch in there and I pushed it and it clicked (I am assuming this tripped). I then turned on the valves and the breaker. My question is, does the power need to be on for me to hit that reset switch or does it work without power on? I am waiting for the water heater to recover so I can not tell yet if the water heater is working.
*Water heater is 5 years old (put in when house was built) and the cold supply line is 59 degrees and the hot out line is 65 degrees which it was before I did all listed above.
Thanks
Thanks
