I have two electric baseboard heaters in a bedroom which are controlled by one thermostat on the wall. I moved one of the heaters to a different location in the room, reconnected but it appears I fouled up the wiring somehow as when I turned the breaker back on at the service panel both of the heaters come on even though the wall thermostat is turned off.
During the relocation I did use a junction box in the crawl space to connect the heaters together then I had to wire the one baseboard heater I did relocate. To confirm, both heaters come on with the thermostat off.
I'm pretty sure this is a basic error on my part so a kick in the right direction would be appreciated.
Thanks in advance....Ron
