I have an electric baseboard heater in a bedroom with a built in thermostat on the heater itself. Heater is 240V. I want to bypass (or remove) the built in thermostat and install a wall mounted thermostat (single pole line voltage) on the opposite side of the room. I will use 12/2 NMD 90 red wire for the extension to the thermostat.
My main question is do I need to have the thermostat between the electrical panel and the baseboard heater, or can it be wired so that the wall mounted thermostat is at the end of run? I have wired lighting circuits where the switch is at the end of the run (a switch loop). Is there an equivalent for electrical baseboard heating?
I can disconnect the built in thermostat no problem and bypass it. My original intention was to connect the new extension wire to the source wire (at the baseboard heater junction box), run it under the room to the other side and up the wall to the thermostat, then run another extension wire from the thermostat back under the room and back to the baseboard heater junction box, and connect the heater as normal.
This seems to me to be unnecessary extra wiring, but it may be required due to my setup, and convenience. Maybe a switch loop type circuit won't work with 240 because both sides are already hot.
I obviously don't want to install the wall mounted thermostat above the heater!
