Seems this will be an issue. building is 60x100. Will have 1, 12x14 OH door and some window openings around the building. Due to having foam under slab and radiant tube, I cannot back a truck into the building.
Every finisher I have talked to pretty much does not want the job, quoting nearly what the concrete costs just to place and finish.
What I need to do is spoon feel the concrete team by working out this placement problem. I have not worked around pump trucks much but one guy mentioned if the flex tube is too long, the rock likes to try and separate from the portand. Don't need that.
Due to a strict air barrier detail in the exterior of the building, I cannot just peel off roofing. I know there is a way. I am not the first person to pour a floor in a building.
Obviously, I can throw enough dollars at the problem that I can hand 100 men 5gal buckets and we got it but I don't have bottomless pockets.
