I have a question for the forum: I am trying to create some lower venting for my attic, which at present has only a few dormer vents and two gable vents that are near the roof peak. Nothing to bring air up from the lower part of the roof. I have installed solar-powered attic fans in two of the dormer vents and they seem to help, but I suspect they would be much more efficient if they could draw air from down in the eaves.
The problem is, my eaves have no soffit - behind the fascia the rafters rest directly on the wall, and there is a 22-inch piece of 2x4 between each rafter to block the opening. Nails and screws hold these pieces in from the ends, bottom, and top. There is only 11 inches of space between the fascia and these boards so it is hard to get at them. I've tried drilling and cutting holes in these things using a power drill and jig saw, and am having a heck of a time. Any suggestions?
Thanks!
Thanks!
