Easyboard from homedepot. Remodeling master bath, going with tile surround. Installed easyboard, without furring strips, said i didn't need them. just screw off at studs. At 16" on center, find there is play in the board. Push on it between the studs, and it gives about a 1/4". Anybody use this stuff? Used mesh tape and mortar on joints as well as a water proof sealant. Before i tile, will the thinset offer the rigid strength. So the grout won't crack later! Or should i start over!!!
Suggestions and input pls.
