we live on a large island in the pacific north west.
in a detached 13 yr old bungalow.
today is sunny and dry temperature is 72deg.
lots of windows and doors open.
the rest of the house measures 60% humidity.
but whatever we do the main bedroom which is on the east side never gets to less than 70%!
I suspect the soil below the crawlspace surface you are calling dry is actually moist. The surface looks dry because the moisture evaporates as it comes near the top.
One approach to isolating the source of moisture is to place humidity meters many locations. You would want to measure both humidity and temperature as the RH varies with temp. Then, you need to look at how the air moves through your home. Typically during cooler months the crawlspace air moves up through the house and out leaks near the top. That is why we are pointing to the crawlspace.
thanks all
outside humidity is 60%
yes there are roof and soffit vents.
vapor barrier? I sure hope so, we don't want to dig up the concrete to find out!
Please determine why the discrepancy in the humidity readings with more and accurate readings before constructing a termite breeding ground vapor barrier in the crawl.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
DIY Home Improvement Forum
