Hi. Looking for advice on for a whole house surge protector (in a low to moderate lightning area) - what product to install and where based on my specific breaker panels (main & sub, and has photovoltaics - not worried about the solar panels getting hit - more about surges through the grid). See pic:
As I understand it, there are three options (am I missing any?):
1) external surge protector wired to breaker panel
2) surge protector that plugs directly into double-pole slot
3) a protector that plugs into the meter slot
For the plug'n'play option (#2), I think I need to install it at the top of the main breaker for best response time, but in my case those slots are filled. There are spaces in the sub-panel however, so I guess moving a bunch of stuff around is an option.
I'm open to hiring an electrician for this, but if it's not too complicated for someone with basic DIY electrical experience (I've installed simple circuits, replaced faulty wiring, know how to use a multimeter, and worked with 220V) I'd be willing to try it myself.
For ease of installation (and reasonable protection against brownout/lightning surges), what's my best option? Grateful for any ideas here.
OK, the nugget you are missing is that surge suppressors can share breakers. Also it shouldn't be nearest the top of the panel, but rather the #1 source of surges.
Breakers can be moved around at will. That's provided the last guy left you any wire length to maneuver.
Please read the instructions if you get a panel mount suppressor. Most say to mount as close to the main as possible to stop external surges. Some also want a dedicated breaker.
If the wires from the circuits are too short to move you can splice additional length. It doesn't matter if they were cut initially.
The plug on is simplest. Just move two circuits to the subpanel. If you have room an external mount is fairly easy also.
1 and 2 are the same in reality, difference of mag wheels and steel wheel.
You do not have access to the meter slot and I suggest that you do not waist your breath talking to the POCO. They do not care about your problems only their own.
Surge protectors all have a let through voltage. What you want is one that clamps down the incoming voltage to something that will not fry your wiring. Like >1000v.
Now that you put a surge protector on you STILL have to provide a protector at the POU.
These protectors can not handle the surge at the panel but can handle what the panel surge lets through.
I offer these pages for your knowledge,
Click here to find the best whole house surge protector you can buy to protect your electrical systems.
www.galvinpower.org
Now for the bad news, NONE of these devices are forever. Just like tires on your vehicle.
I replace my panel unit after every medium to large LOCAL thunderstorm. I do not mean 2 miles away. Or every third monsoon season.
Lastly and still bad news, IGNORE all claims about duckets being paid to you for damage if the unit fails. This is ALMOST IMPOSSIBLE to prove for payment. If the wires are two short get conductors at least the same size and stranded and splice them longer. I use compression crimps for this when I have to. I prefer MTW wire rather than just stranded.
Thanks - I did read about this elsewhere. Some offer less expensive replaceable modules vs replacing the whole unit - do you prefer one kind over the other?
The breaker-type surge protectors are easier to install, but usually have lower max surge current specs than the externally mounted types. My feeling is that you should have as much protection as possible, so why skimp just because the breaker type SPD is a little easier to install.
If you are comfortable moving and/or installing a new breaker in the panel, then installing an external SPD is not much different. The most important thing is to keep the wiring as short and as straight (no sharp bends!) as possible.
Makes sense - thanks, RAL238. I have not installed or moved breakers. It doesn't sound like rocket science, but I think I read somewhere that even when you shut off the main breaker, there are still parts of the breaker panel that have current - is that true? Not keen on zapping myself.
On the topics of UPS, I want to use a high capacity lithium-ion power source. I found the Delta EcoFlow, which looks nice but purports to have only "entry-level" UPS because it takes 50ms to switch over. They say it has "passthru", but I can't tell if that means it is constantly charging/discharging the battery (which would quickly wear out the battery if used constantly as a UPS) vs true switching. One person wrote "The Ecoflow Delta is not a good UPS replacement because its inverter is always on and its battery is always topping off when it's being used in this way, which will degrade its NMC battery pack in the long term." Anyone know if this is true?
Get a UPS with LINE INTERACTIVE topology.. Just get a regular unit, and if you need more run time, tear out the internal battery and use the wires to hook up your own. I have an APC BACK UPS 750Pro that I got free because the battery was toast.. I just hooked it up to a deep cycle AGM marine battery that provides 2 hours of runtime.
32 posts and no-one mentions the absolute best surge protection you can get.....under meter SPD usually installed by the POCO. And if you talk to your POCO real nice they may even install an SPD on the transformer can itself if lightning is a threat in your service area.
One thing I don't know if anyone has mentioned: your electric provider may have a deal for you. I live on a NC barrier island where we have frequent thunderstorms and occasional hurricanes. The electrical co-op that provides my electrical service came out and installed a Powerguard surge protector for me underneath my electric meter. I don't remember what it cost but I remember thinking at the time that it was cheap.
My motivation was a nearby lightning strike that fried (among other things) a TV and my dishwasher. I decided there and then that it wouldn't happen again if I could do anything to prevent it. I haven't had a bit of problem since.
When I cut my grass I always glance to make sure the red ring at the base of my meter is still lit.
