I am working on the design of a new duct system as part of a remodel we are doing. We are replacing an electric furnace from the crawl space with a new heat pump in an upstairs utility closets. I have performed a Manual J analysis and found that I need 550 cfm downstairs and 320 cfm upstairs.
My thought is to do the following for the supply ducts:
- Start with a 14" round duct off of the supply plenum
- Then use a 14x12x10 Wye with the 10" feeding upstairs and the 12" down stairs
My concern is that the 12" duct will be 40' long even before I split off to the individual registers. Do you think I should increase this to 14"? My concern is that the 14" would be too big making most of the CFM's go downstairs and not enough upstairs.
Thanks!
Thanks!
