Hi everyone,
I live in an old house (over 100 years old), with a new furnace and old ducts.
Essentially I have one bedroom and one bathroom at the back of the house that feed from the same duct and are not getting a lot of airflow. Those rooms are significantly cooler than the rest of the house in the winter (I live in Canada, temperatures can get fairly low during winter).
I asked an HVAC professional to come and take a look and his conclusion was that there's really nothing easy to do because the duct feeding that bedroom has a lot of 90 degree angles (to go around a joist) and is undersized (6"). His recommendation (of course he recommended fixing the whole system first) is to install a booster fan in the basement, just before the duct disappears into the ceiling. I perfectly understand that a booster fan is not the ideal solution but at this point in time, I have little interest in opening my walls to fix the duct work, as this would be a massive undertaking and the house was renovated less than 10 years ago (you'd think the previous owners would have updated the ducts at the same time..).
Anyways, what's your opinion? Can a booster fan push that air up to my second floor (straight duct coming from the basement)?
Will it be noisy? In the bedroom? In the family room near the mechanical room? On the main floor?
I've never seen one of those installed, so I have a hard time gauging their efficiency, and the risk of hating the extra noise.
Do you have any advice I could use?
Thanks!
Florent
Thanks!
Florent
