Re: Dual Run Cap & Data plate unreadable. Can manufacturer help, given other equip sp
There should be a model # and name on top of the compressor. Get that and google it and you can get the tonnage. If you can find the info from Copeland it should give you the cap size. Maybe Miller can help with that info.
You could accidentally go larger and it will give it more horsepower. We have universal fan motors that can use a 5/7.5 or 10 mfd cap and give you .25 or.33 or .5 hp with the same motor. Not recommended to go higher but it is not lethal from what I know. Too small will definitely overheat it. You can use a 440 VAC on a 370 cap but not the other way around.
