Pic below shows tubing from the front side of both Pressure Switches T'd together, and attached at Combustion Chamber and OUT PRES port of gas valve. There is also tubing, that you can't see, attached from backside of both (I'm assuming both) press switches, and T'd together into one line that attaches to the Secondary H.E. I believe it correct to say these pressure switches are looking for an imbalance of neg. pressure between comb. chamber & secondary HE., in which case an imbalance would shut the furnace down.
The pic below is a screen capture from a youtube.com video, and its author made this statement: "what the tube going to the gas valve is for, is to put the gas valve in the same pressure area as the comb. chamber." Since a tubing connected to the OUT PRES port of a gas valve normally measures pressure (psi, not IWC), I'm having trouble reconciling the author's above statement.
Grateful for a different explanation of this author's statement.
