I was thinking?
Do you think that Spray Mount (adhesive spray) for pictures. Can be used to spray the wall of drywall. And later used with drywall tape. To make a better flush between the joints using joint compound.
I have used other material to make my seal work. I want to know if this is a better way to make the drywall appear very flat?
Well, you could always give it a try. Personally I can tape fast enough and smooth enough that It would nor help me. Also, smooth joints are more about feathering the joint out wider.
Roofmaster
Fiberglass drywall tape comes with adhesive on it. You stick it on the joint, then bed in mud with a 6 inch knife. What are you taping with, paper tape? I would hate to see what the adhesive overspray will do to your finish.
