1 - 7 of 7 Posts
I have never installed drywall yet, but will be installing it soon on my house. I have 70 sheets of 5/8" and 48 sheets of 1/2" to install.
I am wondering if it would be worth it to go to the expense of buying a dedicated drywall gun (about $80), or if I could get by with just using one of the drywall screw setter bits that you can use with a cordless drill/driver (I already have the drill/driver) ?
Has anyone used both, and if so, how much better does the dedicated gun work ?
I also already have a cordless impact driver that I used to install my subfloor and noticed that I had better control in not over/under driving the screws than I had in using the cordless drill/driver.
Is that a viable option for installing drywall as opposed to the screw setter bit ?
Thanks,
Arky
Experienced
Personally, go with the dedicated drywall gun, they are lighter duty, but also lighter overall.
Purchased one years ago, and have never regretted it.
Mark
Next Time...New Build
With that much to hang a dedicated drywall gun is definitely a good choice.
The impact does make setting screws a little easier. As you said, you have good control which makes you less prone to run the screw through the paper of the board. I have used my impact on a number of occasions to hang board, but not that type of volume.
Used to use an old Milwaukee drywall gun that ran like a champ.
Go to:
http://www.bigskytool.com/Drills_Fasteners___c466.aspx
They've some reconditioned ones for < $50. I bought a Hitachi reconditioned drill, recip saw, light, batteries 3 years ago for real cheap. They come with full warranty so how can you go wrong?
I have no vested interest in this company; there may be other such deals out there; this is just an example. :)
I would go with a collated screw gun, the screws in strips cost a little more, however you can fly with one of these, the time you will save will more than cover the cost of the screw strips, I have both a collated and regular screw gun, for smaller jobs, I will use the screw gun, but if I am going to hang a whole room, I get out the collated. I would not get the screw setter bits for that much drywall, they strip to easy and are a hassle.
1 - 7 of 7 Posts
