I use a 1/4 inch small crown stapler----however,using drywall nails work well,too.
Fill the metal corner bead with 20 minute 'easy sand'--that's the powdered mix.
If you don't like mixing mud then All purpose will do--it's not as hard as 2- minute,but acceptable.
Avoid using light weight topping mix as it doesn't stick very well.---Mike---
