Hello all,
So as you already know, the outside vent is in a location which is a real problem for me.
The reason is because the hot air, lint, and hair is blowing directly into the condenser unit. Besides heating up the coils, the lint is building up on the compressor side of the condenser, and limiting the cooling capacity up to 25% (unless I'm out there constantly cleaning it). I thought about turning the outlet 90 degrees so that it's blowing the opposite direction...but then the flapper wouldn't stay closed. There's really nowhere on the wall to move the hole because the dryer is positioned on a shared wall with a bedroom. There's only three feet of outside wall between the bedroom and the outside doorway. I could move it higher up the wall but I feel like that's a band-aid because the hot air and lint is still moving down in the same direction.
OK problem-solvers...now is your time to shine. I know there is a solution that I'm overlooking...Help me please!
