Yeah, I remember that. I thought it was pretty cool too.Since, I have seen here on the forum a magnetic connection, wish I had that.
I believe you meant to say "gas dryers vent CO carbon monoxide, (not CO2, carbon dioxide). We all exhale CO2 which is harmless.My first choice for venting a gas dryer is 4" smooth round alum duct, and the seams sealed with foil tape, ends clamped, no screws. But if that is not possible, the accordion will work. The slinky snake isn't a problem by itself, unless its kinked. Shorter is always better, but may run the risk of kinking it. The finger sized gap at one end needs to be fixed asap. Gas dryers vent vent CO2, so a large hole in the line would be venting CO2 into the living space. I would remove it, straighten out the nipple and reattach. Tape and clamp.
The telescoping rig someone mentioned above do work, but they reduce air flow, and clog fast. Have never used the magnetic type.
It worked real slick but I never tried removing the dryer, don't know how far it stretches before letting go.That is pretty slick.
Certainly makes it easy to remove the dryer and then clean the lines.
At Home Depot, lots of the boxes were opened and parts echanged into other boxes, to suit customer needs. Perhaps better to order from Amazon to get a box that's more likely to not have been tampered with?
Regarding your last opinion, which I very much understand, doesn't just apply to Big Orange, it also applies to Big Blue. Appliances routinely come in damaged even though the box doesn't look damaged at all. Also, customers are known to help themselves to the pieces they need with open boxes.Last opinion: At Home Depot, lots of the boxes were opened and parts echanged into other boxes, to suit customer needs. Perhaps better to order from Amazon to get a box that's more likely to not have been tampered with?
The house down the road from me burnt to the ground. Total right-off. I have not heard an official cause from the fire marshal, but the story going around at the time was that it was a dyer fire.Makes me wonder why more houses don't burn to the ground!
