When drilling holes in the top plate above a panel, is it typically done from the ground or the attic? I may need to drill an additional 3/4" hole. It's extremely difficult to get to the corner of my attic. The ceiling is very low, and accessibility is limited. My fear is that if I drill from the garage, I will hit a wire with the bit. I'm trying to figure out the best way to do it.
Super Moderator
Cut out the sheet rock, then drill the hole, or get a short bit and drill from the attic.
Even then there is a chance to hit a wire.
Can you feed through the other holes already there?
